Old 02-18-2014, 08:02 PM   #62 (permalink)
Cobb
The e brake helps for making sharp u turns, sharper regular turns and parallel parking in tight areas.
Never had manual brakes, whats wrong with fully functioning vacuum assisted brakes?
Those 2 red wires up on the firewall by your brake booster is to your glow plugs. That fuse blows over time and can cause them to not work.
Back in the day VW owners waved and honked at each other giving the peace sign.
Thats not the stock muffler. Straight pipe gives better torque on small engines and less to rattle apart.
You using kleen diesel(SP?)? The stuff in the little grey bottle? Yeah, diesels love that. Then in cold, cold winter time the white bottle that include a antigel solvent.
