Originally Posted by t vago
I would not say that a clutch "always" had slip. Normally, slippage only occurs as the clutch is being engaged or disengaged. If the clutch were slipping as it were fully engaged, then I'd say that you'd have problems.
You would then disagree that a clutch can slip when engaged, even when outside conditions and changing parameters are constantly changing?
