Originally Posted by redneck
Install the MPGuino. (you can't tell what works and what doesn't without it)
Duct tape the hub caps or rims. (simple)
Duct tape and or cardboard grill block. (simple)
Inflate tires to 50psi. (simple)
Pull the intake hose from the cold air intake and let it pull air from the warm engine compartment. (simple)
Screw the cruise control it is counter productive...
Fill gas tank with non ethanol. (simple)
Coast engine off on the down hills. (simple)
Keep speed to 60mph and below. (simple) Arrive alive...The person is dead and is not going anywhere.
I hope everything works out for you and your family.
Have a safe trip...
cruise control is fine for a non-ecomodder. remember, OP has two other drivers with him. it is better to set the cruise to the speed limit than flying down the interstate at random speeds. my wife can use the control. she won't stare at a guino.
for an ecomodder, cruise control is not so good...
