Old 02-21-2014, 10:36 AM   #21 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Originally Posted by sarguy01 View Post
So, under some of these circumstances, would you not agree that a good clutch can slip?
No. Like P-Hack said, a slipping clutch is a broken clutch. Or an incorrectly sized clutch for the desired application.
If clutches did slip (even a little), you would be able to see it on the tachometer when it did. But you never ever do.
