Old 02-21-2014, 08:33 PM   #18 (permalink)
yoyoyoda
Originally Posted by Arragonis View Post
Update today - my local specialist checked the fluid level for me (for free!) and noted it was at the right level and of good quality - at that point I said it had just been changed so that got a thumbs up.
Good good gooD
So maybe it is in a state of shock ?
Poor thing, maybe give it some comfort by talking to it ?
Here is your problem:
Did you start the learning process when the car is on a hill? if so then that could cause some problems for the transmissions learning process..
In Subaru’s case, a Transmission Control Module sits at the heart of their four speed adaptive autobox. Sensors tell the ECU (Electronic Control Unit) when the car’s going uphill, downhill or around a corner. The black box directs gear changes according to event-specific algorithms designed to make those experiences “better.” Selecting Sport mode calls-up a different internal 'map' or program which allows higher engine speeds during acceleration, and delivers more responsive downshifts when the guy in front of you doesn’t slide over to the right.
I would suggest that you re-start the learning process and just park it on a flat surface until everything has settled down.
If its at all possible =D
