Nemo, according to the manual this main relay is the only one for the pump. I can manually engage the points on the fuel pump relay side and the pump gets proper voltage and runs fine but it still won't start until it gets the proper ground or power from the ecm or sensor in distributor that tells it the engine is turning. It acts like it is either a bad ground, a bad soilder in relay as mentioned, or the ecu going bad. If my resoildering don't help I may try to add an additional ground in the circuit and see what happens. Thanks again, Mike
