Old 02-23-2014, 09:33 PM   #67 (permalink)
freebeard
Isn't the problem with that vw trailer and so many other bullet shaped trailers is that they are almost backward. The tow rig is already pushing the wind, the tailer just needs to close it.
Also seems like the top should be outside the bottom if nothing else it sheds water better when up.
There's a current thread—"Kamm-back" (K-form)... that's relevant to this. Like the Airstream Basecamp it gives you a place to put the door. "Faster backwards" is a meme you will see crop up here occasionally. A rounded nose has benefit in crosswinds.
I think they lapped the top inside to protect the windows in transit.
55lb not counting the battery? Holding tanks (plural)? Water is heavy. If you ask MetroMPG nicely he can merge this thread with your intro or vice versa.
