Old 02-26-2014, 12:23 AM   #78 (permalink)
American Viking
American Viking's Avatar
Dad's Jetta - '05 Volkswagen Jetta 2.5l package one
90 day: 23.23 mpg (US)
Black Cherry - '01 Honda VFR800fi
Last 3: 39.39 mpg (US)
Where are you all coming up with 80 Watts???
A car has at least two headlight bulbs for low beam running. So the average halogen setup needs 110 Watts of power (55x2). If you have a car that burns both beams when you select the high beams then your running 220 Watts when you use the high's
The Cree for H7's use 27 watts, doubled for a pair of low beam headlights that's 54 watts. That's less than even the 70 watts of most true HID conversions. Burn 4 (2 lows & 2 hi's together) and your still not drawing as much wattage as your car would with a pair of halogens low beams.
Next time you worry about wasted wattage, take your stock 55w h7 out of the headlight housing and hold it in your hand. Quartz is a good insulator, so if it is hot enough to burn your hand on the outside, imagine the power wasted as heat inside the capsule!!
That wire in the halogen capsule is radiating energy across a wideband of the em spectrum, where as the LED is mostly converting the watts to a handful of wavelengths in the visible light spectrum.
JohnS
Black Cherry (no epa ratings)
Dad's Taxi
The Lead Sled (EV conversion coming soon)
