Old 02-26-2014, 10:41 PM   #44 (permalink)
Detail Man
02 Civic - '02 Honda Civic LX
90 day: 40.32 mpg (US)
Originally Posted by digital rules View Post
Sounds a little late for best efficiency.Not sure, how low your car is geared, but I generally shift between 1500-2200 RPM. RPM's kill MPG's.
3rd-15-20 MPH
4th-25-30 MPH
5th-35-40 MPH
In heavy stop & go traffic, I tend to go lower to avoid constantly shifting. If only very slow acceleration is needed I will go down to 1000 RPM's.
These are about the shift points I use, but I have a tach and shift at 2000 rpms usually. I find that if I'm in fourth and holding my speed, it's time to shift to 5th.
Originally Posted by 96CX View Post
Well, I'll have a go at earlier shift points, then. I just filled up, I'll do a tank of shift-to-5th-asap, and see what I get.
Meanwhile, I've got a check-engine light, so I'm seriously considering ordering a scangauge in order to check and reset the codes instead of paying a shop to tell me what the codes are.
Advance Auto checks the codes for free around here. I think Auto Zone does as well. You don't need to pay for a gauge just to check the codes. And yes, the Ultragauge checks codes.
If you can accelerate (even slowly) in a given gear, you're not yet lugging the engine. When you can floor the pedal with no result, it's time to downshift.
