Old 02-27-2014, 05:07 PM   #1 (permalink)
IsaacCarlson
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
Regear results and some problems
I had to replace the axle in my truck this last month. The old axle had a loose pinion nut when I got it, so I snugged it down and have been driving on it for 3 years. It finally went poo. I called around trying to find another 3.55 but all they had were semi floaters, so I picked up a 4.10 floater. It was in pristine condition with .015 backlash. The wheel seals had already been replaced with self running seals. It feels good. I filled it with royal purple at $20+ a quart
My old springs were broken and worn out, so I got new springs too. The door sticker called for springs with over 8 inches of arch, but that would put my rear end into the stratosphere. The springs that were in there were aftermarket because they had 4 inches of arch and were heavier than the door code. I wanted something a little heavier, so I ordered 43-701 springs rated at 3,000 lbs each. They ride much better than the old ones and sit a little higher, which is good. It lets me leave some slack in my leveling valve, which will save air with lighter loads.
I drove the truck after installing the axle and was getting around 20 mpg. Two days ago, I drove to Bloomer, which is about 40 miles round trip and burned a 1/4 tank. The truck was louder than normal on that trip. I pulled it into the shop when I got home and looked it over real quick. The fuel pressure was 45 psi and 55 psi with the vac hose disconnected, but it dropped to 0 as soon as the motor shut off. I will do some more checking on this, but I suspect dirty/sticking injectors.
I did find that the vacuum canister was leaking, so I disconnected it and that brought the idle way down and made it rough. I have a list of things to check today, if I get the time.
I will check compression, vacuum, and ignition as soon as I can. I just replaced the oxygen sensor last year, but will check the wires. I will need a new condenser soon because the wire is corroding. It does no good to ask for help on the ford trucks forum because they waste too much time calling bs on everything. They insist that this kind of mileage(low) is NORMAL.
Anybody got any ideas? I have wanted to make sure the injectors were clean for a few years, but never had the guts to pull them. I might just pull them for peace of mind if nothing else. I have no idea how many miles are on this truck. It could be 60,000 or 160,000 or 360,000 I don't know.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
