Old 02-28-2014, 10:47 AM   #307 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Originally Posted by TheSGC View Post
The AVC2 module is the circuitry that came with my J1772 socket. It provides the Pilot signal to the charging station to activate the power. It also has a relay connected to the Proximity that can enable/disable the charger or car when the J1772 is being plugged in.
Could you not ignore the included circuitry and hook it up in a much simpler way? I think a resistor between proximity pin and something else (chassis ground pin?) is all you need. If it's the challenge/project aspect (seeking to make the pilot signal work for your amusement), then I totally understand.
