Old 02-28-2014, 10:45 AM   #2 (permalink)
oil pan 4
Is that even possible? Make enough power with a kubota at that rpm to go 70mph?
In factory configuration most of the 3 cylinder engines are around 1L or less and only make 10 to 12 horsepower.
Now if you turbocharged it then you would get another 10 to 20 % more horsepower and fuel economy.
I think you might need more horsepower if you want to maintain the speed limit on anything but level or down hill ground. Every 1% of grade increases power requirement around 20% to maintain your speed at 60 to 65 mph.
