Old 02-28-2014, 09:25 PM   #308 (permalink)
TheSGC
Originally Posted by mechman600 View Post
Could you not ignore the included circuitry and hook it up in a much simpler way? I think a resistor between proximity pin and something else (chassis ground pin?) is all you need. If it's the challenge/project aspect (seeking to make the pilot signal work for your amusement), then I totally understand.
You could wire up a few resistors in the required setup, but this module came with my J1772 socket so I'm going to use it.
Civic EV http://2001-civic-ev.blogspot.com/
Solectria Force http://solectriaforce.blogspot.com/
