I know you can do gear swaps in ranger, there are a few different axles you can swap out from various years to get close to the desired gear with out breaking into the diff.
Since GM, the king of rebadge and parts bin engineering made the tracker there has to be rear gear out there in something else that will fit it. A few people have modded them on here but I don't know if a gear swap was among their mods.
Where you going to get that 2203 motor?
Not sure where Im going to get the motor. There are suppliers in MO and TX that Ive looked at. I would like to find one locally here in Tulsa but Im not afraid to go get one within reason. My plans are to do both a Ranger 4x4 and I found a slick Tracker with a bad motor that I would like to try a 3 cylinder kubota in...if I can get the gear ratio to the 3.55 range
