Old 03-01-2014, 12:18 PM   #9 (permalink)
Freedom92
If no one knows of a source of gears for that tracker then swapping in another axle from something else might be be the only way to get it.
I never got to work on a kubota in the 40hp+ range, anything that big had a toyota.
Thats kinda where Im at now on this. It would be an awesome swap if it werent for the gearing being too low. I guess at this point I need to know what rearend would be the best fit for the job. Ratio needs to be in the 3.31 to 3.55 range. Could even be 3.00 and I could adjust with tire diameter.
