Old 03-01-2014, 08:11 PM   #1 (permalink)
sarguy01
sarguy01's Avatar
Mazda5 - '12 Mazda 5
90 day: 25.22 mpg (US)
Big D - '11 Dodge Durango Crew
90 day: 18.75 mpg (US)
10$ Air Dam. Another One.
Edit. ABA testing in. Need more testing...
Route was one mile long. Set cruise at same points and canceled at same points. Used Torque to data log.
A - Two runs, ran both ways, with the dam.
B - Two runs, ran both ways, without the dam.
Here are the numbers:
MPH MPG
A Run 1 51.44 32.46
B Run 1 51.97 32.66
A Run 1 51.48 32.83
A Run 2 51.26 33.68
B Run 2 51.13 33.43
A Run 2 51.74 34.02
For Run 1, this is a .06% loss.
For Run 2, this is a 1.25% gain.
Using median, to rule out outliers, I'd be at a .13% gain and a 1% loss.
Not what I was hoping for. 1.25% is hardly a gain for me. That is a .375 mpg increase. Hardly conclusive.
Original Post:
I had some time today to get out in the garage. I had to run to Home Depot for some other stuff so I grabbed the $10 lawn edging. Here are the pics of the install. No A B A testing yet. Hopefully I can get some testing done soon. I am hoping there will positive results like the rest of the air dams usually produce.
This is version one. If I find it needs to be beefed up, I will. I am leaving it like this for now.
The pics are pretty self explanatory.
Here is the aluminum angle I had sitting in the garage and the lawn edging.
Before...
Here is the first piece of angle attached to the bottom of the bumper.
I used this saw to cut the angle. Took seconds for each cut.
Yeah, I used sheet rock anchors to go into the plastic bumper. They were free.
I just drilled through the edging and riveted it to the angle. Pretty simple.
This stupid sticker didn't come off. I started riveting and realized it was there. I tried to rip it off and it didn't come off. Ughh. I'll have to scrape it off. Someday.
This is the side view. The edging, width wise, goes from the outside of one tire to the outside of the other tire.
If I missed something, please feel free to let me know.
A grill block made of roof flashing may be coming soon. A WAI is also going to be tested, as soon as I make it and get some free time.
The Following 2 Users Say Thank You to sarguy01 For This Useful Post:
TexasCotton (03-02-2014), user removed (03-01-2014)
