Old 03-01-2014, 08:33 PM   #7 (permalink)
Cobb
Reverse cowl hood? Helps to suck air from under the hood vs push air up under the engine bay. You see these off and on by someone who got it right and wants function over show.
Maybe dumping air in front of tire gives leadway for it to be sucked behind the wheel once rolling and into the brake? Otherwise most brake cooling uses ducts to the caliper.
