Old 03-02-2014, 05:07 PM   #15 (permalink)
Cobb
Thats about the same for the insight. You need to apply light pressure on the throttle, just enough to remove the play so it is not assisting, not regen braking or in EV mode. Yes, light throttle will engage the IMA system only, maybe its an easter egg? That allows you to coast as best you can, however you are still spinning the engine, but the valves are closed.
