Originally Posted by Rennie
Picked up a 1998 starlet life for 1 k , will be arriving tomorrow. Nice and cheap considering most are double the price or triple/quad if I wanted an echo  Now I have to get used to the no tach cluster and the heavy steering even though it's only 800 kg or so  At least it will still be economical while I learn how best to drive it.
For the heavy steering try and adjust the caster angle back to zero until you feel comfortable with the steering. Don't go negative caster. always keep a tiny bit of positive caster, it improves the feeling of on-road stability and feeling like the car is going in a straight line when putting down power.
Most FF cars dont have caster adjustments, my toyota doesnt but I can get a rubber replacement which gives it caster adjustment.
