Originally Posted by RustyLugNut
There are numerous books and papers that discuss combustion dynamics, but the basics follow the outline to increase flame speed and the heat/pressure release to drive the piston.
Note:
Increases in Flame speed does not necessarily increase power or efficiency.
For example:
The Lean Burn operation in Gen-1 Insight is actually a slower flame speed , but yields a higher energy efficiency... where the rich burn in the same engine has a faster flame speed , but a lower energy efficiency.
I will briefly discuss the first four points as a group and then the last point in a more extensive fashion as that relates to the original post. As both Niky and Tvago have pointed out, water injection and EGR change the chemical reactivity rates and surprisingly to some, they can be used to accelerate and stabilize certain flame situations when all logic tells us they would quench the flame.
Bold
Incorrect.
