A common oil leak for the older Civics is the rubber in the distributor. I know your taking about the shaft that slides into the valve train. But if you take off the distributor and tear into it, there is a rubber seal at the bottom that bakes on there. All those distributors are the TD41U? So might be better off buying a new one.
