Originally Posted by jeff88
It's coming together nicely, can't wait to hear what kind of numbers you pull.
Just had a thought... when you have the trailer fabbed up to how you want it, you should put a generator inside, attached to the wheel and eliminate your alternator for even more fuel savings!
I can't tell if that's a joke or not, but it won't work. The alternator is belt driven, and has a power draw from the engine. Your concept would be wheel driven, and have the same (if not more) power draw from the engine. You could spend a lot of money putting peltier panels along the exhaust line, and possibly eliminate the alternator, but pulling along a wheel to do a job that the engine is doing now simply will not work.
