Old 03-06-2014, 09:04 PM   #1 (permalink)
IsaacCarlson
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
Vacuum level back to normal
I have been working on the truck today. I removed some more of the old smog equipment that has been hanging out under the hood. I also checked for vacuum leaks and removed some old tubing. I pulled an injector out and the filter was a rusty color. I ran some air through it and it seemed to let a good amount through. I could not get to the rest because of the intake plenum.
I did a compression test and all cylinders were at roughly 110 psi on the first compression stroke and topped out around 150-170. I was expecting a lot lower numbers, so these made my day.
I did a vacuum check and it is back up to 20 inches at idle and holds steady until the engine misses, then it drops a touch. I still think it is a dirty injector causing the misses. I can't find any more leaks. I replaced the plugs, cap, and rotor. It runs better and smells better. The old plugs were black, so it was running rich, which I already knew. All of the plugs looked the same, which is an improvement over the last plug change.
I am going to steam clean the top end since the intake and cylinders are dirty. I plugged the idle control back in and it does not try to run sky high now that the vacuum leaks are fixed.
I still need to see how the values of the temp sensors compare to new ones.
So far so good.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
The Following User Says Thank You to IsaacCarlson For This Useful Post:
Cobb (03-07-2014)
