e-money, this leak is between the dizzy housing and the head. i think that if it were some seal inside the dizzy that was leaking, it would leak oil into the dizzy and then drip out between the cap and housing. this doesn't appear to be the case but i will remove the cap and check.
cbaber, yup: #6 is the o-ring i've replaced twice now. i already replaced the VC gasket and used silicone sealant in the 45* (ish) corners. no change in the leak. i've wondered about the possibility of the wrong dizzy as well but if that were the case, i think these o-rings would fit the head (since the head and o-ring are verified as being stock) but would be loose on the dizzy. i'll check some part #s anyway to rule the incorrect dizzy out though.
thanks for the ideas!
