Celebrex is a cox 2 inhibitor with a lot of side effects. I swear someone I knew died from its effects and I had internal bleeding from taking it. No issues with the ticker.
Vioxx is the counter part to celebrex incase you got a funny system that requires left vs right handed module medication. Or is that right vs left?
Anyhoo, the harder drugs are cox 3 and numb the pain because its better.
Back pain is from many things. Some is from soft tissue and muscle. Other is from pinched nerves, bulging disks, compression fractures.
When back pain starts to make your legs or back side of your thighs numb, effect your ability to pee, then you got some series stuff going on. Depending on how your nerves are effect it can make you weak too in the legs.
