Glad to know that doing the big three will save me some fuel:
http://ecomodder.com/forum/showthrea...rth-28378.html
I noticed the slightly brighter headlights too, whiter and brighter at low beam and high beam.
For now though I'm just using the existing wiring and just cleaned up the connectors going to the chassis and to the starter motor. In future I will be replacing all of the cables though as you did as I believe it will improve things even further.
And the charging of the starter battery will be more efficient too, less power is then wasted in the resistance of the wire.
Good job, and welcome to the forum
