Old 03-09-2014, 04:16 PM   #6277 (permalink)
flores
EV Connoisseur
Thanks Paul.
I have a clamp amp meter that goes up to 1000A, but need a co-driver to check becuase all the high voltage wiring is in the back.. but will check it soon..
Is the 1000A out of beta if it works for me? The controlboard isn't that different from the 500A right? only the power stage is different.. but only the by the number of diodes and MOSFETS.. right?
You mentioned IGBT's.. should I convert it to that for testing? you mentioned plans with that... I'm willing to try anything for more poooooowwwwwweeeeerrrrrrrrrrr (quoting Jeremy Clarkson here)
The Following User Says Thank You to flores For This Useful Post:
MPaulHolmes (03-09-2014)
