I have already gone from a 16 to 17 tooth sprocket on the front and put on a 39 from the stock 41 but can't find anything smaller any ideas?
I took a quick look at JT sprockets website on your behalf, there is an 18 tooth front sprocket available which has the same fitting dimensions as the superhawk, catalogue number JTF 339. I can't say for sure if there will be enough clearance for the larger sprocket, JTS are very helpful it might be worth asking their advice.
Regards,
Ironside.
