Originally Posted by Cobb
Did you run the numbers to see if this makes financial sense? Since the Honda Insight has been discontinued you should be able to get a much better deal.
How so? You referring to leftover Insights or Prius's (Prii)?
Long story short, hybrids hate hot weather over 100 degrees as it shortens the battery life and most limit warranty in hot states. Second, they hate to be parked. They must be driven weekly if not daily or the battery life is shortened.
Interesting (disturbingly)...I hadn't heard about either of those limitation from ANY of our local (AZ) Toyota dealerhips visited.
Cold weather cuts your mpg by at least 20mpg and the more heat you use the less mpg you will see.
Cold weather typically isn't our (Tucson, AZ) problem, it's the hot summer months (100-115ºF) that I'm worried about; but it would affect MPG.
