I really need to go clean mine. The Metro was very sensitive to having corroded grounds. I added more on the Metro and it did help, even after I cleaned the factory grounds.
The Civic has an uninsulated ground going from the chassis to the engine. It is greenish from corrosion. I might just make a new one since I am worried that the corrosion is also inside the terminals.
