Old 03-10-2014, 09:39 AM   #11 (permalink)
yoyoyoda
Originally Posted by sarguy01 View Post
I really need to go clean mine. The Metro was very sensitive to having corroded grounds. I added more on the Metro and it did help, even after I cleaned the factory grounds.
The Civic has an uninsulated ground going from the chassis to the engine. It is greenish from corrosion. I might just make a new one since I am worried that the corrosion is also inside the terminals.
What really works I've found is just pouring boiling hot water straight from a kettle onto battery corrosion. It melts away the crystals like they werent even there. They just disappear before your eyes.
Just be careful you dont splash any on yourself.
I actually had a problematic battery which would need this done once a month or week, I would go and make a cup of coffee before leaving and bring out the kettle with me lol to pour onto the battery terminals.
Worked like a charm.
