Old 03-11-2014, 08:58 PM   #92 (permalink)
Cobb
True Dat!!!!! Got to stick a small air nozzle down each one, and let it dry before you go bolting.
Originally Posted by ECONORAM View Post
Make sure the bottoms of the bolt holes are well cleaned out with a bottoming tap before running the head studs down..or you'll hydro lock any fluid at the bottom of the holes and CRACK!
