Thread: 98 Superhawk
Old 03-11-2014, 08:40 PM   #8 (permalink)
jkv357
Originally Posted by American Viking View Post
If the 18 will fit without hitting the cases or the guides, I'd go with that.
16/41 is a 2.563
17/39 is a 2.294 or 11% less revs
18/39 is a 2.167 or 18% less revs
If you want more efficiency, than that, you'll have to re-jet and/or downsize the carbs.
Then the only thing you can really do after that is reduce friction and weight (both rotating and non-rotating).
This would be a good bike to consider - Ecotrons EFI conversions on it. Probably could use the EFI Throttle Bodies off an RC51.
Or you could just get something that started off getting big numbers - like a CBR250.
You will never overcome that much more displacement/power than is required to propel a typical motorcycle at a moderate speed.
Just have fun with it, because there's really no reasonable way to make it get seriously high MPG numbers.
