Originally Posted by mazdamx640
Oh and no luggage bags on the bike I hate the way they look I just wear a backpack
BTW my last bike was a 99 vfr and witch I consider to be the best bike ever!
Okay, so no luggage, but you are thinking EFI. Still your adding your weight plus a backpack to the bike.
If Supersprox.com can make 36 tooth rear sprockets for an rc51 which has a larger center hole and bolt circle than a SuperHawk, I'm sure they can make a 35/36/37 tooth rear for a SuperHawk.
And for best mixture when you go EFI, I'd go with a highest pressure system you can get with the smallest injectors.
I'd also consider the 190/55 tire, because your probably going to want to add a suspension link that will raise the rear of the bike, giving you plenty of clearance for the taller tire.
