xfi vs custom 181 cam test
I getting ready to test these 3.52's in a '96. I am starting out with a rebuilt engine (.020 over, around 10.25-1 compression,1.3 flywheel). There is a new cam out from Crower that has a 181 duration (very high torque/low rpm cam that works better then the xfi cam. I can't post links yet but you can see the test for yourself. Go to youtube and you can find it under ... Geo Metro XFi Camshaft vs Custom Grind.
