No need to have me compare the ratios on 88-2000 Civic SOHC 4-5 Transmissions, you'll find most of the info...I'm part of it. Here is a Gearing Calc I helped on making sure all the D series ratios were correct. They have been my "passion" for 15+ years now.
Honda Transmission Calculator by ZealAutowerks
As the cars got newer, they got heavier and therefore couldn't take advantage of the longer gearing. My 89 CRX HF was weighed under 1800 lbs by the previous owner. 96+ are likely 2400-2600 lbs w/0 driver.
