Originally Posted by California98Civic
Does not seem to be the case. Been running this thing for nearly two years. Passed California smog test 6 or 8 months ago.
Now I have something to read about!!!!
Blundar (PGMFI.org) didn't think just killing the injectors would work and the ECU would freak out.
Question: What are you doing with the throttle when cutting the fuel?
On my old car I had adjusted the TPS so that I could crack open the throttle while coasting down in gear, ECU had shut off the injectors but the cracked throttle didn't allow the engine to slow the car as much, hence farther coasting. Aprrox 13 miles was my record for longest coast. Great Smokey Mountains from Newfound Gap down to Cades Cove....
