Old 03-13-2014, 12:11 PM   #20 (permalink)
Hex
Originally Posted by Hex View Post
My main goal is fuel efficiency which seems to be yours as well, WD40. I assume if you're considering refurbishing your original injectors, you must not be totally satisfied with the OsideTiger injectors because of their aforementioned difficulty to keep them efficient in lean burn. If this is true, I may just have my stock injectors refurbed as well. You're pretty much about to sway my choice one way or another, so I appreciate the added feedback.
I ended up having my injectors refurbished by OsideTiger almost a year ago and I'm very satisfied with the results. The injectors definitely perform better and I did notice a slight increase in MPG. This is how they arrived; vacuum sealed with new o-rings and an extra along with the old replaced parts.
