Old 03-14-2014, 06:01 AM   #4 (permalink)
Mista Bone
I know 92-2000 Civics do, down to 1200 rpms under high manifold vacuum conditions. Automatics have an issue where the injectors don't cut out as much.
If you use a bouncing light show, aka air/fuel gauge, you can see when the injectors are not turned on.
