Originally Posted by Mista Bone
the spin of water draining is dictated by design, not the earth.
Two toilets, same maker from late 60's, same out, the water spins in opposite directions.
If you lived on the equator, would water not spin at all????
The direction can be influenced by design but not fully dictated by.... The hemispheres do dictate the direction. A passive drain in a tub has no influence and they are opposite for north and south.
You can spin the water the opposite way in a passive basin drain. It will always stop and turn the way it wants to after it reaches equilibrium.
