Old 03-14-2014, 08:21 PM   #7 (permalink)
j12piprius
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
Originally Posted by bestclimb View Post
With the ultragauge you can tell if your car has cutoff by observing one of the various O2 sensor gauges. Then you have to tell the ultragauge that your car has DFCO for your instant MPG to reflect zero fuel.
Are those the Bank1 O2 1 (and 2) voltage sensors?
They are on 1.275 volts. What should they show with DFCO?
I have set the following:
menu > ultragauge setup > injector cutoff = 11 (1.6 liters x 7);
menu > vehicle setup > VE enable > on, and > VE rpm > 5500 > on.
