Old 03-15-2014, 07:13 AM   #54 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Originally Posted by paulgato View Post
As for the PWM controller idea, that 10A PWM unit should be suitable for the heater blower but you might need to bypass it with a switch for the highest speed. At 12.5v my blower motor takes about 16A at full speed, 8A at speed 3, 4A at speed 2 and 2A at speed 1, and at 14.5v those motor loads will be proportionately higher of course, so 19A at full speed and 9.5A at speed 3. I got a 15A PWM so I would have to do the same thing and bypass it for speed 4.
...but why are you using a PWM for controlling DRL's? Are the DRL's on your car just the headlights fed via a resistor?
I suspect 10A will be fine in the real world as the 3-4 settings are a bit too much really. Ideally, I want to buy a spare blower assembly to convert to brushless power.
I have a set of Phillips DRL8's. They use a PWM controller to improve effciency/life and dim them when the main beams are on. Problem is they are automatic so they switch off after ten seconds of EOC. A basic PWM controller will mean they're always on in the ACC position, with the option for dimming with main beam/ park light still there. I also like the idea of gradual dimming via an Arduino when the vehicle is stationary to further save power.
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
paulgato (03-15-2014)
