Old 03-15-2014, 12:02 PM   #7 (permalink)
botsapper
PSmodder lurker
Active spoilers. Still like Aeromotions computer-programmed active-assistance split rear wing. It could be set to have an aggressive performance profile for a dynamic and required downforce split to either left rear or right rear wheel depending on cornering maneuvers. It fully deploys in straight braking or split deployment when braking in sweeping turns or at sharp turns. The wing is set to neutral/low drag during top speeds.
The Following User Says Thank You to botsapper For This Useful Post:
bobdbilder (03-23-2014)
