Old 03-15-2014, 02:26 PM   #56 (permalink)
aerohead
185-200
Originally Posted by ssnsvibe09 View Post
I had two upper grill blocks install and the lower one on for a few days but the temperature was hitting 200. so I took off the lower one, to lower the temperature down to around 185, but your recent posts had me thinking to swap things around.
This morning I reinstalled the lower one and removed the right hand side.
Where is the temp. sensor monitoring location ? Some cooling systems run at up to a 'normal' 255-degrees F.
