Old 07-06-2008, 11:16 PM   #1 (permalink)
bgd73
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
make the car heavier to gain mileage?!
as the title states. It does happen.
As some may remember the crazy wobbling inline transverse of yester year (now unlikely to be so sloppy), when motor mounts were tightend, body structures failed.
As we all do not live in paradise for sheet metal, I do not know of a failure that isn't possible, to this day.
I recently have been working with a 21 year old subaru. knobby tread, 15 inch wheels, AWD 5 speed dual range, and a claimed weight of 2300 pounds. After doubling the rocker panels, adding frame work, wheel wells, rear quarters, all welded...I gained fuel mileage. The frealy little car sounds like a monster truck with the thumping studless snow tread on the hot tar at 35mpg.
the engine became a rock in its spot. It occured to me...short stroke little engines lose for every movement against thier fire stroke. Adding roughly 21 pounds of steel permanently in strategic locations of structure added fuel mileage, regardless of my -20s F winters to 90 degree july.
A thought to ponder no doubt....
Of course boxers and inlines do many opposites, and fuel injection may like the shaking, I am working with a carb original 1781 cc boxer. Smooth tread is back in the
high 40s mpg on the highway.
Just thought I would throw the idea out there if anyone has reached a dead end with thier little engine being a hog for no apparent reason. This is an odd reason, but worth a mention.
