I don"t know about were you are but we have places that sell only bearings and seals. If you don't have a part number they just measure, look up the size and can usually come up with something workable. With a seal you need the shaft diameter as well as the outside measurements. Maybe there is some place similar online if you have no local resource.
PS Have you checked other forums for a part number for a substitute someone must have already found something that will work.
