Old 03-16-2014, 05:48 PM   #46 (permalink)
chumly
sizematters - '08 smart 4-2 passion cabrio
90 day: 51.99 mpg (US)
escape - '06 Ford Escape xlt
90 day: 26.78 mpg (US)
Buick - '04 Buick Park Avenue Ultra
Team Turbocharged!
90 day: 27.26 mpg (US)
No more pictures but it was simple, I just drilled two holes (one on each end) into the plastic grill pieces that have the foglights and used a piece of threaded stock and nuts on each end. The licence plate frame holds it in the center and one wingnut with washers on each end is all I needed to hold it on. This way if the car starts to run too hot I can remove it in a few seconds but so far I only did it once, interstate driving with ac and 100+ F outside temperature. It was running warm but not too bad, about 210, and I found out later wasn't anything to worry about. Chumly
The Following User Says Thank You to chumly For This Useful Post:
Eric839 (03-16-2014)
