Originally Posted by Hersbird
The transport is what came to mind, the axle would have to be moved to about the front door area, the current front and rear wheel areas just filled. You could even hide the new wheels behind the doors but leave them functional so if you had a flat you could still access it just by opening the door.
Looking at Lay's research,if reversed,the Pontiac might show in the range of Cd 0.20.That's as a backwards van.
Drafting close to the tow vehicle,it's Cd would be lower,as well as the tow vehicle.
