Old 03-19-2014, 08:30 AM   #57 (permalink)
suspectnumber961
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
With my 03 Focus I have an upper grill block and 3 removable clip-on blocks for the lower grill for use in winter....which vary the opening. I also use a plywood front "pan" to streamline and divert air under the engine.
I aim for over 200F coolant temp from the readout on a Scangauge...which I always monitor. I also installed an LED to indicate when the coolant fan runs. With the Focus...the coolant fan comes on at 233F and goes off at 222F. Temp very rarely gets above 233F...before going down.
Have run this way for maybe 2 yrs or so. Am somewhat concerned by the heat under the hood causing cooling hose failures...the newer hose materials will not show deterioration...the rubber and fabric will just get weak to the point of failure....heat is the enemy. The LED indicator will give me a chance at least to avert disaster.
IF a hose goes...you won't see steam...since it will blow back behind you. How do I know...had this happen with a couple of cars...head gasket time...at a minimum.
In summer...I sometimes have the fan come on in town in slow traffic. Will be removing a strip of foam tape under the front edge of the hood to enable a bit more fresh air intake this summer.
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
The Following 2 Users Say Thank You to suspectnumber961 For This Useful Post:
aerohead (03-21-2014), sarguy01 (03-25-2014)
