Old 03-19-2014, 01:53 PM   #73 (permalink)
RustyLugNut
This is a good analysis.
Originally Posted by cbaber View Post
I did some poking around the interwebs, and found some good info. If you were to compare emissions of a standard gasoline engine to a lean burn engine straight from the exhaust with no cat, the lean burn is much cleaner. Lean-burn actually creates less NOx and CO2.
The problem comes with the catalytic converter. Normal gas engines operating at 14:7 produce the right "mix" of gasses that react inside the catalytic converter. This reaction significantly reduces NOx emissions. With lean burn, the mixture of gases entering the cat is not ideal for oxidation because of the already lower NOx and CO2. Therefore special cats and other emissions control systems are required to further reduce emissions inside the cat.
So lean burn isn't the problem, it's that catalytic converters are more efficient at cleaning up the dirtier air from regular burn than they are from lean burn, so you end up with worse emissions after the cat on lean burn engines unless expensive new cats and emissions systems are implemented.
The emission levels dictate the use of Three Way Catalytic Converters (TWCC) to reach allowable outputs.
Lean burn engines can reach those same output levels but with after engine clean up technology that mirrors clean diesel tech. And, those technologies are not cheap. Particulate filter traps or oxidation catalysts and NOx absorption traps as well as the required purging circuits would mean a relatively expensive engine. The market would not bear this in small passenger applications.
